Very loud and annoying main board ventilation fan noise
Hi there!
just received the A1 and very surprised by the main board ventilation noise. Really annoying.
Do you also experiment this? Maybe it comes from my unit?
I’ve just measured the noise at idle with mainboard fan only.
To me it is way to much, far from what I expected and obviously much more than my former Prusa Mini+
May I kindly ask one of you to measure this on your own printer, before I submit a ticket to the support team?
Many thanks in advance!
Cheers
HGO
Is that sitting idle or printing?
2 weeks ago I was investigating a printer fan issue for 20-30min until I got the idea that the board that is laying on could make the noise more noticable. Grabbed the printer and hold it in air until printing. So sileeeeeeeent.
It was not A1 but since then I have tested it on another printer with IKEA LACK table and it is sooooooo noisy.
So just in case try putting it on something hard and heavy. If you have floor that is not wooden is great way to test if this is your issue too.
In general WHILE printing with fan off (i checked the profile it says 60% if layer is more than 80 sec or smth) or at 60% not sure I can barely hear the thing. NO chance if it is not nighttime therefore very silent.
But I can measure it somehow if wish
Same here, I have received my A1 mini a few days ago and I find the main board fan very loud and at frequencies which make it quite annoying. At which distance did you measure the noise level ?
Hi,
probably form the same production batch, since mine arrived on the 2nd of December.
The noise level hase been measured 50cm from the printer.
I did open a ticket, they will send me a replacement fan.
Hopefully it will solve it, this noise is so annoying.
Thanks for you answer and your comments.
I tried to grab th printer in the air, the terrible noise is still here. For the moment the furniture on which the printer is placed is sturdy. It is definitely an issue with fan itself.
BBL immediately decided to send a new fan.
Cheers
If you want to file a ticket to BBL, it is better if you attach some video, and noise level measurements.
KR
Hgo
OK I am starting to worry now as I received mine the same time.
As I have nothing to compare it out.
How can I see if it is okay or not? Can you do a video?
I had a super noisy main board fan in one of my P1S units. Bambu sent me a replacement fan. It resolved the issue.
Hi,
Thank you for sharing your experience. BBL sent me a fan, I’m waiting…I’ll post an update when it has been replaced.
KR
HGO
What´s your update on this? Did it solve the issue? I also have an very loud fan…
Hi there,
Short update :
-fan replaced, with a new from BBL. Noise level is the same, but more constant and less annoying.
-I printed a TPU sole for the new fan, which I placed between the fan and the heat dissipator of the drivers on the main board–> didn’t help much.
-To me, the main issue is that the main board fan is not controlled in close loop, it just starts acording a preset.
-All in all that is a big dissapointment for me, the general noise level of this A1 mini is much higher than a Prusa Mini (external power supply, passive cooling on mainboard).
Hopefully BBL can fix it in further update?
BR
I got my A1 mini this week in June and have the same issue. The mini is way louder then my 5 year old printers. The mainboard fan is very annoying. So I don’t understand why all the YouTuber were talking about how quiet it is. It is not. I hope someone finds a solution.
I could not find any way to control the mainboard fan. Is there even a gcode to control it?
Hi,
I got my A1mini 2 weeks ago (December 2024) and have exactly the same problem - still. Fimeware is now already the 1.04. without any improvement. Especially that it runs forever in idle and sometimes doesn’t stop making noise at all. Especially when you have moved the head via app.
really bad.
Is this also the case with other Bambu printers? Then this is the last printer from them. I’d rather spend more money.
Prusa is supposed to be quieter.
Anybody tried the noctua fan mod?
makerworld: 509241-bambu-lab-a1-mini-noctua-fan-mod-for-silent-use#profileId-425236
These printers are near silent ? Do you not have the noise canceling software on? My PS4 in the background even drowns it out, 50 DBS is, let’s be honest, resting rate in a house out of the city. So maybe calibration…
There are some screws on the bottom of the fan that can be backed off to get rid of rattling noises. It seems the clearance is really tight and sometimes the screws can be tightened to such a degree that the housing flexes and the fan rubs on the inside of the casing.
There is no main board fan ?!!
