Warped bed :( seems like a common QC issue
Haha, I just realise that your idea is great, you print a support material or PETG plate of 5mm with a ABL fade of 5mm and then you can print above this a perfectly flat PLA object ! , never thinked of that before
The ABL does not measure the edges, but extrapolate the mesh data from the inner parts. But if the inner parts are halfway flat and the edges are not, it cannot work.
Yes, yes, I posted an issue on github about this some weeks ago, they will change that soon : Bed levelling should make measurements on the borders of the plate (and may be more measurements) Ā· Issue #1559 Ā· bambulab/BambuStudio Ā· GitHub
For those with significant machining and metal working experience, I’d like your thoughts. I was looking at the edge of the aluminum plate from my original bed.
It sure looks like it was stamped out, rather than routed out.
Probably with some sort of edge finishing after stamping.
The website compresses the picture too much for me to be able to tell. I’ll probably take my bed apart in a week or two. May be water jet or laser cut too. I wouldn’t expect them to mill out the plates shape honestly. No reason to be that precise.
This would be great to have in Orca.
Yes, I plan to make my own magnetic glass bed. But also my own fiber plate bed.
I was going to try to make the fiberplate magnetic on both sides so I can avoid using any clamps. Worth a shot.
Well, you can already do a try in both Bambu & Orca slicer using the M420 gcode
have you actually checked the measurments results?
each point mapped at room and at high temperature?
the changes are not the biggest and again it is the edges that is the problem due to the plastic frame not beeing aligned.
yea when heated things warp, but please look and compare how much! sure, if you are looking for Micrometer accuracy , this is true, the bend is bending, but we dont see any milimeters here…
We are actually seeing changes in the range of up to 0.3mm when heating, if the measurements above are precise, more on the edges then the center.
And 0.3mm is not a huge dealbreaker compared to nearly a full millimeter, but people had complained about values much smaller then that already.
I managed to get my bed from 0.7-0.8mm warp down to 0.08mm just by uninstalling it from the printer. It must have had quite some mounting stress to flatten itself out so much and the new bed I installed did not have such problems. I still believe its more a QC problem then a general design problem, else every single bed would be affected, which clearly is not the case.
It’s 100% stamped. Very obvious if you look on the corners.
much valid point there!
As you say, it is mainly the initial bending, i do like your comment about pretension in the support frame.
I am still manually waiting for a new magnetic surface after manually making the metal sheet straight and shims out the plastic edge that on my both bed was a huge issue (0.5-1mm)
but i will try remounting my frame at elevated temperatures and see if any change
Tested GCODE M420 S1 Z10, and it seems to not works.
I have sended an issue, as it would be a great feature.
Another hint that the firmware is not just a stolen Marlin :slight_smile:
Multiple people have confirmed, with measurements, that the plate changes at temperature.
Right, the changes aren’t the biggest, but they are still changes.
Since the plastic frame has a higher coefficient of thermal expansion than the metal heat plate it’s screwed into, it’s expanding ever so slightly more, which is causing minor variations in the surface.
This is about what I’d expect when doing the math. I’m not sure what exact plastic the frame is made out of, since I can’t find any stamp marks (maybe someone can check their removed bed and find it for me), but I’d assume it’s a plastic that has a CTE of about 75 (aluminum is about 20).
256mm x (75 x 0.000001) x (60C - 20C) = .76mm total linear expansion
The smaller aluminum plate is only expanding about .23mm at the same temperature (again just an estimate since I don’t have exact measurements of it). The plastic frame is pulling at the thin aluminum plate and causing thermal stress and variations in the surface that are fractions of a mm.
Aaaaaaaaaand with these last few comments I’m out of my league and will let the learning process begin
You guys are sure smart and I’m enjoying reading all of the test results while waiting for a viable solution to the issue
Thanks everybody for your knowledge, testing and input
With all of the talent chiming in we’re bound to find a good solution
GoodNews friends :slight_smile:
I am the guy from GoodPlate and I have some information:
  1. I do ship again to USA and UK. Sorry for any inconvenience. It took quite some time till I had figured out how customs works (correctly) and how to package the stuff that even it arrives overseas well. Seems like these shipping companies are a little rough there… Unfortunately I need to charge additional 5 € for USA/UK for additional packaging material. Really sorry about this.
  2. I am looking for a partner in the US who might wants to import GoodPlate on Bulk. So all of us can save HUGE amount of individual shipping cost and mitigate long waiting/delivery times. Please PN me if someone is interested. Unfortunately we can start earliest in 4 - 5 weeks for bulk imports till I receive my EORI number (another annoying customs paperwork stuff which is required for bulk …). Individual imports is no problem…
  3. I could not find asap who did silicone his glas plate, but Kudos to him. It inspired me and I did the same (I did not want to handle the clips anymore). Guess what it works perfectly!! Even with high temp 100° C. I have used a standard bath and kitchen silicone which is heat resistent up to 150° C. Here are some pictures. I also updated the documentation on my website …
Cheers Friends
The only problem is that silicone is permanent and mechanical removal will damage the magnetic bed. Glass will, eventually, take on the shape of the bed as well.
Unless I am missing some easy way to get rid of silicone when desired
Keep away that stuff from electronics and aluminum, when curing it emits acetic acid which causes corrosion. Get neutral cure silicone which does not damage things. Even though description says it adheres to aluminum, it’s a total garbage to use on any metals as it’s acetoxy cure type.
Thats true. I am continuously measuring the flatness. So far it looks good. Once if it really takes the shape of the warped bed I will completely remove the magnetic surface of the heating bed as it was mentioned and shown before in this forum. Leaving just the aluminium bed and put the glass directly on that as it is done with Ender 3D printers.
