I don’t see a way to do this, but we need a way to be able to remove a model from a contest. Like lets say we messed up and had a model enter that we shouldn’t of. There doesn’t seem to be a way to remove it from the contest.
I read I don’t remember where, that you just have to make the model private to remove it from the contest, you risk nothing by testing
but then it is completely invisible to the public. I think he rather demands a way to remove a model from the contest but staying visible. otherwise you have to delete & re-upload. …and this could either be an illegal way when you already received points for the model…
No I am talking about like if you want it public, but not in the contest.
So lets say you make a functional print and maybe another print but this other one is for the contest. You accidently add the wrong print to the contest. There is no way to remove it from the contest as far as I can tell.
A simple fix for this is maybe a button on the contest page where we can remove some of our projects from the contest.
I knew about if you won. But I guess I overlook the policy on just uploading it to the contest.
Personally, I think you should be able to remove it from the contest at any point unless if you won. But I’m fine with a 2-hour window. Luckily I haven’t ran into this problem. It is just something I noticed.
