Webcam cable
Hi, anyone know the name or type of cable usen with the webcam? I want to move the webcam in the top front.
I made an enclosure with 2020 profiles and acrylic and i want to make better time lapses moving the webcam.
I want to change it or extetend with M-F cable (MF cable is the easy and best option).
Thanks i go to buy one female to male (i prefer to avoid to cut the original cables if its possible jejeje).
edit: i Bought two cables one male another female with 30 cm cable perfect for extend. Idk the distance limit but i try without break nothing (to large maybe have to many power loss).
This connector isn’t a micro jst 2.0, is smaller (arrived and it’s to big) i go to try to see what name have in reallity.
Have you found the type of connector you need? I’m also looking for the name of the connector. There are 5 pins, the pitch is 0.6mm and the width of the male part is 5.8mm.
Can someone please tell me what each of the wires in the webcam cable is for?
Didn’t even realise the webcam could be moved?!
2 are for ground, one 5V and other 2 pin probably for information strasfer. led is not controlled by a voltage in the other 2 remaining cable.
Did you figure out which cable worked?
I found the cables. The type of connector is called “Micro JST 1.0 SH 5-Pin”. I found an Amazon listing with the title "5 Pairs of Micro JST 1.0 SH 5-Pin Male Female Connector 1.0 mm Coupling with 15 cm 28AWG PVC Cable (1.0 SH 5-Pin) ". I tested the connector and it fits on the camera/light module on my Bambu Labs A1.
Do you have a link ? I would like to try6 to wire in my own camera.
Here is the link to the ones I got:
amazon[.]de/dp/B0BNCFHJTF
It’s from the german Amazon.
You need a “Micro JST 1.0 SH 5-Pin” connector. The “1.0” in the name determines the size.
The wires go to a module that contains the camera and light, so not sure if you will be able to connect your own camera to that.
I only needed to hook onto the power cables to add a 5V LED strip, so I did not do anything with the data cables.
I know it is an older topic, sorry.
I’m searching the specs of the connector with the idea of use it when led is on as signal to control a led strip.
If I understand your message, this is not going to work, right?
