Weird behavior with multi color print
Hello Bambu Community,
I’m working on a multicolor print and encountered an issue. I’ve positioned the items upright and used the layer painting tool to apply colors (see picture 1), then laid them flat for printing (see picture 2). The top and bottom layers print as expected (see pictures 3 & 4), but the middle layers behave strangely. Specifically, the red and orange colors bleed into the white area (see picture 5), which causes the colors to show through the print.
Does anyone know what might be causing this issue? Any suggestions would be greatly appreciated!
Welcome to the forum.
Can you upload the .3mf file that you are having issues with as this really helps with solving the issue.
Here is the 3mf file
Repsol Mirror.3mf (455.3 KB)
I think that the “weird” shapes of the central layers are intended to provide strength. If the red-white and orange-white colors were the same shape all the way through they would probably be very weak along the boundaries.
Try increasing the number of top and bottom layers to prevent bleed-through.
As @lkraus mentioned, the geometric interlinking of colors is intended to provide strength between areas with different colors. On flat shapes with few top and bottom layers, this interlinking is of course not really desired.
An alternative to increasing layer counts, you can also use modifiers to locally change the filament.
This only fixed the issue a little. Is there no way i could go about it otherwise? It really needs to be exactly like colored
Im not sure how to do that. How would i go about that?
Just to show the concept (you’ll want to size and place the modifiers):
Repsol Mirror Modifier.3mf (443,8 KB)
Quick How-to:
  1. Merge the parts
  2. Right click parts → Add Modifier → Cube
  3. Select the modifier, size and position
  4. Right click the modifier → Change filament
  5. Rinse and repeat for further modifiers
You can also change infill, speeds, layers, walls, …
Very useful indeed :smiley:
This worked perfectly, thank you so much man. You are a saint!
