Weird blobs after last update
Since the 1.5 firmware update, I’m getting weird artifacts all over my prints. See image. Does anyone know what caused this?
Printer has been fully calibrated after the update, Ive printed this file before with the same filament and that came out spotless.
Its all on the ‘outside’ see next picture.
Bonsoir.
As tu essayé de sécher ton filament ? Car cela ressemble à un problème d’humidité.
I havent dried it, I didnt have any issues yet with the filaments, all spools are the same age, about 2 months. Might try it, just seemed odd it happens after the update.
Essaie quand même de le sécher. Peut être que tu es arrivé au moment ou le filament a dépassé la quantité maximum d’humidité. Personnellemnt, mes filaments sont dans des sacs hermétiques avec 4 ou 5 sachets de silica. Et même mes ABS et ASA ne me posent aucun problème.
same issue, after updating and auto calibration i have bad filament texture
That looks like your retraction, can you check if the blobs coincide with the “seams” in the slicer? The white dots in preview.
Its not at the seams, they look okay to me. The PLA seems brittle, so I’m trying to dehumidify them in my conventional oven at 40*C at the moment. Lets see how that goes.
So after tinkering for a while, I noticed that the k factor of my filament had reset to 0. I changed it to 0,02 (standard for eSun PLA+), and now it looks fine. Thanks for the help tho!
