Weird noise in one corner
My P2S has started to make a weird noise when the print head leaves from the front left side of the print bed.
It doesn’t make it when it enters the said side, only when it leaves it. When the print head gets closer to the back of the print bed, the noise gradually goes away. So it’s the loudest in the front left and almost non-existent in the back left corner.
And the noise comes from the upper front left corner.
It’s not a metal kind of grind. It’s a weird combo of plastic scraping and/or something resonating and it lasts only not even a full second. I have a video clip but the forum won’t allow me to post it.
The rods are lubed and greased and I take the maintenance seriously.
What could be the source of the noise?
Can you post a video showing the noise happening please?
Sound like your linear rods might need some lubricant oil. How long have you had this printer for and when was the last time you did maintenance?
Sounds like a brief mechanical bind at the front-left idler rather than a lubrication issue, since you already maintain the rods. Move the head a few centimetres out of that corner along one axis at a time and listen: a noise that appears only when leaving means the belt unloads against that idler. Inspect the front-left idler for a rough bearing and the belt edge for fraying, then watch the PTFE tube and cable chain as the head departs; a link catching the frame scrapes briefly, resonates, and quietens as the head moves rearward.
