Whambam PEX plate - [solved]
I have just installed my new whambam PEX plate, added the little QR-CODE sticker to the correct position on the left tab, prepared the PEX surface with alchohol and fine scotchbrite.
I also added the tuned start / end codes from here: Printables.
I then set the bed temperature to 50 degrees and ran the print, but the printer stopped saying that it did not recognise the build plate and do I want to continue or stop, so I continued.
Adhesion seemed to be OK, and the XY Cube printed well and was easily removed when the bed cooled.
So how can I add this custom plate to the bambu Studio so that it recognises it and does not prompt me each time a print is run ?
