It looks fine when viewed from the front.
Uneven layers are noticeable when viewed from above or below.
The filament used is BambuLab PLA BASIC.
I went through the K value and flow rate calibration, but it’s the same.
The improvement method I found was
The solution was to disable the “Slow printing down for better later cooling” option in the Cooling tab in the filament settings.
However, if you turn on this option, normal printing cannot proceed!
Is there another way?
↑ outer wall speed when ‘Slow printing down for better layer cooling’ option off
↑ outer wall speed when ‘Slow printing down for better layer cooling’ option on
↑ print cube when ‘Slow printing down for better layer cooling’ option off
