X1C. Bambu black basic pla. K value .21. Standard speed. Standard .20 settings. Nozzle .4. Temp 220. Bed 55. Hunidity 14%. Door closed. Fans off for first layer. They r long runs.
The rippling is either slight overextrusion or bed adhesion issues. I’d go with adhesion as a first shot. Wash plate, use glue stick, hotter bed, lower 1st layer speed. Maybe bump up the first layer thickness a teensy bit.
Clean the rods with IPA ![]()
Hi All, I’m new proud owner of a X1 Carbon with AMS and I’m confused about the first layer I got yesterday.
I’ve cleaned the bed, reset the printer to factory settings, performed a auto calibration and result was better but not perfect, there is still some bumps in the first layer.
Could you advise what else I should do ?
So ill tell u what i did may or may not wrk for u. I put on the engineering plate and retrammrd as per bambu instructions. Then i switched to the plate i was gonna b using. I then proceeded to print a first layer over the whole bed and while it printed i adjusted the bed knobs. When i was satisified (but not yet perfecrlt but close). I then did a bed level w that plate. Now the whole first layer whole plate is prefect. Fyi it took about 10-15 first kayer prints to get it close.
I have the same issue, on all build sheets. happens in the same place every time
when looking under the right light I can see bubbles on the build plate. Since this is a consumable, I’m doubtful they’re going to replace mine for free, but it clearly is the problem.
I have this exact problem on my A1 mini. What is interesting is this only happens when I slice models in Bambu Studio. In Bambu Handy, everything prints 100% perfect. I even printed a plaque that consumed the entire print bed. The plaque was printed from Bambu Handy without any issues. Immediately after, the next print was sliced in Studio, with this exact result you have. Then printed something else from Handy with perfect 1st layer. I have repeated this many times.
Contrary to all the recommendations on tramming your bed, I believe the issue is a first layer problem in the slicer that was introduced at some point in time, such that the pre-sliced models have no issues.
Had the exact same problem with first layer issues in BambuStudio. Tried the same model in the Bambu handy app and now it works perfectly. I am not sure what the problem was but that solved it.
Just as an update, this has not been a problem for me is quite some time. Just make sure the bed is clean. I clean my build plate with down power wash, and dry with lint free paper towel. The key is to make sure your cleaner is a gentle degreaser. Once cleaned,
can print for up to 2 weeks without cleaning provided I wipe it down with a fresh paper towel and a small amount of filtered water.
My problem ended up being a worn/dirty Extruder unit. I didn’t bother cleaning it and just replaced it and the issue went away. I’ve had my X1 for over a year and figured the plastic parts inside the Extruder would be a little worn anyway even if I would clean it.
So just put a new module in.
Do you think the slicer on Bambu Handy has a different version of the slicer? I never tried using Bambu Handy.
Does Bambu Handy actually do any slicing? It seems way too fast to go from model to print. I thought the models in Bambu handy are pre-sliced. I could be wrong, I absolutely do not know — it just feels like they are pre-sliced.
