What could be the cause for this?
You haven’t mentioned what brand of filament you are using or what printer you are using?
A printer in this setting you probably should have purchased the Pro version which is specifically designed for these constraints.
That’s why they have the Pro version that’s got 100Mbps ethernet built in.
Also I see you’re running ABS - I had to go through the printer settings and do the “high temperature bed leveling” to get good full-plate results with ABS
Soap and water …
