What could this be?
I found this laying on my print bed. Anyone know what this is? I thought it was part of the nozzel wiper, but no such luck.
What could it be? Hmmm… :thinking:Based on the limited information and only this picture, I can conclusively say it looks a lot like a screw inside a piece of broken plastic. :joy:
But seriously, unless someone recognizes it, what would help is to give the photo some scale and also remove the screw from the plastic. For scale, photograph it against a known object such as a coin. Better yet, place it next to a metric ruler since all parts on the machine are metric. This will allow us to guess the dimensions.
Or better yet, if you have access to a nut with a known size and pitch try to thread it into that to check the thread gauge - I’m guessing that’s a either an M2.5 or M3
Here’s a table of screws used in the X1 and P1. It is derived from this kit that is available on the Bambu Store. It may help to better identify what part of the printer it came from.
https://us.store.bambulab.com/products/screws-kit-x1-series-p1-series-and-ams
Item Number Item Name Location
1 ST3-4.5 Rear Panel and the Front Cover (Front)
2 BT3-6 P1S panels and the Z-axis Timing Pulley
3 M3-6 XY/Z Motor and the X1 AP Board
4 BT2-8 AMS first stage feeder, the MC board, and the Excess chute
5 BT3-8 Heatbed Unit and the AMS Main Frame
6 MG2.5-13 Cutter lever
7 M3-14 Cutter lever Drive gear of the Extruder Unit
8 MG3-14 Hotend
9 MG2.5-15 Hotend Cooling Fans
10 ST2-3.5 P1S Panels (Upper)
11 M3-4.5 X1C Panels
12 BT3-5 Rear Panel and the Front Cover (Rear)
13 BTG2-6 PTFE tube bracket
14 M1.6-4 TH Board FPC Cable of X1C toolhead PCBs
15 BT2-5 Toolhead housing and PCBs
16 The pressing plate Extruder Gear Assembly
17 0.9×11 mm Helical Compression Spring Extruder Gear Assembly
18 M3-2³ For the AMS Filament Buffer
If you don’t have one in your shop, here’s a useful tool I found indispensable when it came to nut and bolt identification. I found that I needed one just for servicing my P1P, there were so many different screws and this tool helped a lot.
Here’s the category search since it doesn’t look like the one I purchased is available anymore. Forget about the plastic kind, they are useless.
https://www.amazon.com/s?k=metric+Thread+identifier+gauge
Found another post with the same issue. It is from the fan on the print head housing. Not as serious as I had first imagined. :grinning_face:
Is this part of the wiper?
Looks like you ruled this out already.
It does look like a broken post, but why isn’t there something between the screw head and the post? Maybe broken from the toolhead cover; I can’t recall anything else in an X1C that has that color.
Yes, that was rulled out. It turned out to be a mounting screw for the fan in the print head cover.
