Every time I try to print this piece:
I end up with this:
I’ve attached my 3mf file for the print - any assistance would be much appreciated! It consistently fails around 7-8% of the way through the print. I’ll go to check the camera and notice that it’s really stringy and that the build plate shifted from it’s original position so I’ll stop it. I just printed a few RHCP coasters with this red filament a few days ago and they printed just fine.
Iron+Man_A1_mini.3mf (6.2 MB)
Here’s the print after being sliced. Just to give you an idea of what the failed print was trying to accomplish with the supports.
Which plate do you have it sliced on?
Do you dry out your filament? I just fixed a bunch of my printing problems by using a small dryer (S2 SUNLU) to dry my filament to around 20% relative humidity before using each roll of filament.
Hi pics show a PEI plate- and his 3mf is set for a smooth. He never responded, I’m assuming he found this oversight to be the issue and moved on.
