Seems like a stupid question (maybe it is) but please wait.
I most often printed using the profie “0.16 mm Optimal @BBL X1C”, because “optimal” sounds much like optimal.
But recently I printed something using 0.20 mm. The result was acceptable but less good and I started to compare different settings after slicing in the slicer (not print). I selected in the preview to show only one layer.
With 0.20 mm there was allways some print at every layer in the modell when I moved the right scroll ruler up or down.
With 0.16mm there where empty layers (or layers empty for the model but they contained printing for the support).
Also with 0.16 there was a total of 286 layers, with 0,20 159 layers. If you multiply this, then the same model would have different high.
I thought: ok, the layers might overlap. So what is the z-position?
So now I examined again (with a different model, but similar behaviour).
With the bottom ruler at the end it shows the z-movment.
E.g. with 0.16mm at the end of layer 108 it moves to 9.52. Layer 109 is totaly empty, no gcode. At the end of layer 110 it moves to 9.68. Ok, difference 0.16, but with some “dummy layer” in between. But also confusing, it states a layer high of 0.04.
See attached screenshots:
Might be that is not important, but I find it at least interesting.
Note: I also found that the “layer hight” in gcode varies. I found also 0.008 and 0.12.
