What is my A1 doing on the rear right corner of the printbed?
Always after having printed the 3rd layer in a print, the A1 pauses printing and the print head moves to the right, rear corner of the print bed (to an approximate position of x=255, y=250), makes a short motion in -y direction and then resumes printing.
Nothing appears to be wrong with that, but I’m curious what it is for.
Mine does the same thing and I was also curious. Doesn’t impact the print job but just weird.
My A1 did the same thing, even when I disabled the timelaps option.
The only thing I found to completly remove those weird moves was to remove everything in the “Time laps G-Code” in the parameters of my printer. Since I have done that, I have never had again those moves.
Im seeing this still happen in my prints even with nozzle clump detection disabled on the printer. Is there another setting, in the slicer maybe, that I need to tweak?
pretty sure it’s timelapse.
See if turning off Settings > Print Options > Nozzle Clumping Detection stops or reduces the frequency of your printer doing that.
Mine A1 mini does the same but actually it is making a mess sometimes as it doesn’t retract the filament properly and when it returns back, it messes the print with the leaked filament :face_with_raised_eyebrow:
I haven’t found out how to disable it but I would like it to stop doing that as it is completely unnecessary and at most of the time it just messes up the print…
My new A1 with 150 hours of print time also did the same thing, but it was after the first layer. it went out of the dimensions of the print bed, lowered itself below the print bed, and then returned to normal printing like nothing ever happened.
Isn’t this similar to Lift Head in Cura? If the Minimum Layer Time is not met, the printhead will park itself a side for a short moment?
Mine does the same thing also. Disabling Nozzle Clump Detection did not change this behavior.
I have the same problem with quality, because during this time filament leaks from the nozzle and then leaves pieces of stuck plastic all over the model. This really spoils the appearance :frowning:
What do you mean by this? How do I remove timelapse gcode on my printer, is it in the bambu studio settings or the A1 Mini itself?
I have clumping detection and timelapse turned off, and my A1 Mini still does this. Has anyone found the solution?
Ok so I did a bit of digging and it is indeed the time lapse feature, So if you’re in orca slicer you can go to printer settings, Machine G-code and then make your way to “Time lapse G-code” and scroll down till you find this line of code (G0 X261 Y250 F20000) and you can remove it to get rid of that move to the back
hope this helps.
honestly i prefer this sorta thing cause it’s saved my butt like 5 times already
I’m pretty sure it’s making sure that the print isn’t stuck to the nozzle and that the plate is on correctly.
yea, similar to anti blob detection or something
to be fair, don’t remove this. It’s only like two seconds, and also it isn’t related to timlapse; as far as i know its closer to nozzle clumping detection, it moves to the side and checks if theres filament stuck on the nozzle. If there is, it pauses the print. This prevents nozzle clumps from getting far too big.
Thank you! I am brand new to Bambu A1 printing (until last week I used a Prusa MINI) and this being only my third print I thought perhaps I was doing something incorrectly. Thanks again!
