I was looking at various settings on my P1S and came across the term Ramming and I am at a loss as to what that means. I can’t relate what I think of when I use the word Ramming to a filament setting.
It is explained here
For filaments with serious leakage, a section of filament will be quickly squeezed out on the prime tower before switching the nozzle, which is ramming. Cooling down while ramming can further shorten the time of travel adsorption (to be introduced in 4.2 below). This reduces oozing and stringing when switching nozzles without significantly increasing the filament switching time.
Ramming is the process of compressing the tip of the filament by essentially moving it rapidly back and forth into nozzle. It creates a point on the end of the filament which would otherwise be elongated and stringy. This prevents it from jamming in the hotend, or extruder gears etc on the way out. Also makes it easier to feed the filament back in again.
Unless you are Prusa MMU, where you call it “tip forming”
