What is this clicking by my extruder
I am trying to run a Dynamic flow calibration but filament flows for the first 10 seconds then it all changes and this clicking starts. Anyone know a solution?
ELEGOO RAPID PETG BLACK is the filament and it has been dried for 18 hours.
https://youtube.com/shorts/y9r3Ruxjeg0
What temperature are you printing at? Have you tried printing hotter?
270 nozzle. 75 bed temp .
Nozzle is clogged or you have a filament jam.
I think I found the reason and in the middle of a test print right now. Not quite a filament jam, but I think my AMS Lite got moved too far away and was creating a bad angle for the Bowden tubes. The test is going well but I also want to try a different filament.
Nope, went right back to clicking after 2 prints.
Is your spool moving freely? Look and see if there’s a cross over, they can be hard to see once the AMS retracts and spools back up.
Just a thought.
Someone else posted about Elegoo a few days ago (I think) with a similar problem.
Reading Amazon reviews, it seems to be hit or miss lately, maybe they changed their process. Amazon.com: ELEGOO Rapid PETG Filament 1.75mm Black 2KG, High Speed 30-600mm/s 3D Printer Filament Dimensional Accuracy +/- 0.02 mm, 1kg Cardboard Spool(2.2lbs) Fits for Most FDM 3D Printers : Industrial & Scientific
Anyway, since you’ve been printing at 270*, you will have to purge a new filament at 270* or higher to make sure all the Elegoo is out.
I think I found the reason.
That is the back of the Hotend Heating Assembly (the black stone-like piece).
Sorry for the blurry shot but that is one of 4 screws that hold the 2 pieces together falling out as I carefully pulled the assembly out. Screwed that one back in and checked the other 3, they were ALL loose. Tightened it all up and things aren’t making clicking noises anymore. I am guessing that they have been that way since I got this printer (I have never had it apart before) and would explain some of the off and on trouble I have had. Sometimes it prints great and other times it just doesn’t. Hoping this fixes a lot .
Hey I did check the same screws but it doesn’t resolve my problem of cliking! Do you have the clik again or not?
No clicking anymore for me. I started to check them when I get the y-axis lube message and have had to re-tighten them again, just a little but they were loose. Sorry it doesn’t help you.
I regularly hear extruder clicking on my A1 Mini when the temperature is around 140 and climbing to target 220.
