I am trying to switch to LAN only mode on my Bambu X1C, and it will not connect…it was working just fine before… I can synchronize the AMS, but can not send a print file over the network… it tries to connect to LAN only and then fails to connect… I tried all the usual things, restart routers, take down the firewall, reboot pc/printer, etc…
Does the status go back and fourth between connected and this
Yes, it does… now I did get it working by logging back on to regular WAN, then logging out of studio, switching printer to lab only (studio app closed) and then opening studio…
Good luck, sounds like you are having the same issue as me. I made a post about it but have not gotten anywhere, I also have a pending ticket. Im setting up a ubuntu VM as we speak to see if I get the same result when using the appimage.
edit: same result on appimage 1.08.2.56 I would drive this thing back to microcenter if the return period hadn’t just run out.
