What settings are you using for SUNLU?
Curious what settings people are using for SUNLU PETG High Speed. Have to find something I like since it appears there is no information on when Bambu will have their PETG - HF back in stock or if they are replacing it with something else.
Also the preset that shows up in the Studio won’t transfer over to the machine so that’s pointless as well.
I run a X1C.
TIA
You really have to do your own tuning, as some parameters depend on the environment. I had to re-calibrate after I moved an X1C from a small room to a larger room, because the small room held heat better.
That said, I started with the default SUNLU PETG High Speed and changed the following:
Flow ratio: 0.95
Enable pressure advance/Pressure Advance: 0.026
First layer temp: 245
Other layers: 240
Plate temps (all layers):
Texture PEI: 65
All smooth: 70
Supertack: 35
Retract on layer change: true
Retraction length: 0.5
Wipe while retracting: true
I just finished a spool and wasn’t happy… Bambulab PETG HF is better. So now I am trying Elegoo Rapid PETG and it seems to print perfect with the Bambulab PETG HF profile…
Same here. Bambulab PETG-HF wasn‘t available so I orderd some Sunlu PETG-HF.
Tried to start with Sunlu PETG-setting in Bambulab Studio - horrible.
Then I tried the Bambulab PETG-HF setting with Sunlus PETG-HF. Result was better - but still far away from the Bambulab-filament.
Now I have four spools of filament and need to calibrate it as good as possible.
