What to do about the H2D heated bed temperature uniformity problem?
You rock. Thanks for doing the test. The 110v vs 220v or 120vs240 was brought up because they are ac powered beds, so the 2 act different.
Just that 240V might be getting to temperature a bit faster.
Here is a IR camera time-lapse of heating from ā€˜cold’ to 120C.
Each image is 10s apart, so these images cover a 5 minute timespan.
This is a 240V printer, firmware is 01.01.01.00
I think the printer said it was up to set temperature after about 3 minutes.
HD_00002
HD_00003
HD_00004
HD_00005
HD_00006
HD_00007
HD_00008
HD_00009
HD_00010
HD_00011
HD_00012
HD_00013
HD_00014
HD_00015
HD_00015
HD_00017
HD_00018
HD_00019
HD_00020
HD_00021
HD_00022
HD_00023
HD_00024
HD_00025
HD_00026
HD_00027
HD_00028
HD_00029
HD_00030
HD_00031
I would say those thermal images match my measurements quite well regarding absolute temperature values.
Honestly: if this slight non-uniformity is causing print failures, we should search for different materials (plate and filament). There must be some margin…
About 5-degree delta and in thermals, you can see the difference… yeah, that doesn’t look too great.
It turns out the probes went directly above where the heating element was. If @T_guttata would put the probes the other spots, that might settle any remaining concerns people may have.
Sure, I just can’t flap my mind around the fact that $2k printer has THIS bad and low quality heating element… I guess Chinese Chabuduo at its finest… ugh, it works, it may even stick. Good enough. Like why do we even have to discuss this in the flagship printer.
It actually appears to work better than expected near the edges, which is usually a problem zone. It now looks like this might have been the reason why it was laid out the way it was.
No matter what, it’s not as good as the MK52 bed from Prusa or other edge-to-edge heaters.
Thanks. I believe this is the important one.
After the firmware update I have not had any heatbed adhesion problems, so I’d say it works just fine.
You are aware that the heatbed you mention is smaller, and therefore easier to produce? The heatbed for the XL is about 400 euros for 16 tiles. This is double the price of the H2D’s heatbed. (It is slightly larger though).
What’s up with Bambu users… you forgot how to read or what? MK52 is not XL tile.
That’s #1.
#2 - you can open the freaking link up and see how much good quality heater costs… it’s not hard, right? Even for a large-sized bed…
@ Advocado
  • The X1C uses the same principle for heating, alluminum PCB with traces. But as you can see from my previous measurement, temperature uniformity is worse than for the H2D. Therefore, if you think the Prusa XL is better, you should show us evidence.
  • Temperature uniformity is not at all bad. Absolute temperature is what should be improved, and I’m sure this can pe improved with firmware. Good engineering is about finding the right compromise. If the temperature uniformity would be +/- 2°C but the plate would be triple the price, people would complain anyway because of price.
May be it’s just hard for you to see that Bambu has taken leadership in 3D printing in no time? No matter what they do, it is just better in almost very aspect. I hope that Prusa can catch up. Every company needs competition, otherwise people get lazy (Intel is a good example).
I’m guessing this was with the chamber heating off and door open for the camera - so this 13 deg difference, in the real world (where you’d probably heat the chamber if you have the bed set to 120) really could be ā€œapproximately 5ā€ as Bambu claims.
When did I say the Mk52 bed was for the XL?
I don’t see how the MK52 bed is relevant because it’s smaller, and therefore much easier to make flat and uniform. If you are talking Prusa parts for a 300mm bed, you probably to use XL tiles, but fewer of them.
Or you could do what Voron does and put a 300mm bed into a 350mm printer … HAHA
Politics make me unwilling to purchase anything from a US company right now, so Fabreeko is non-existant, but you can get a quality AC-powered 350mm non-American silicon heat bed for about 100 euros. (And to be fair, if you are in the US, Fabreeko seems to be the same price for now, as their stock is already in the country)
edit In any case, the H2D heat bed is working now (at least for me) so what’s your actual problem?
Not super happy with the bed heating issues. First off, sorry as the first photo was taken a week ago and for some reason the camera flipped the image. So the two images are upside down from each other. The first photo was on the original stable firmware and the second photo was on the new beta 01.01.02.04 BETA. Nothing else changed. Only difference I can notice is they increased the temperature by maybe 5c overall. But I’m getting about a 10C difference from high to low. And my PETG parts do warp if the edges are in those cold corners. Note: my final temps will not be super accurate as its from a thermal camera but they should still be accurate on the variance. My thermal gun shows almost identical temps as the thermal camera.
Photo Parameters
  • Bed at bottom of printer( to get a full picture).
  • Print bed pre-heated for 15 min at 110*C
  • Door opened for less than 20 seconds to snap photo.
  • NO fans on at all.
  • There are 3 lines. The two dots on each line is the High and low for that Line.
First Photo, Stable official firmware. 01.01.01.*** (I forget)(NOTE: Camera is flipped upside down on this photo)
Second Photo, BETA 01.01.02.04
Some video they rise bed temp at 10 celsius and then pla stick in bed
I honestly don’t believe that one can solve warp issue only by having a even bed temp. Even if you have a perfectly even 70C bed, parts that are prone to warp, would still warp. After all it’s more about the filament shrinkage rate rather than other things. Essentially what you can do is still to increase temp, add glue or brim, use a clip to hold the plate on bed…
Temperature equilibrium is a big one. This is why a heated chamber is such a big deal for stopping warp. It creates as small as possible of temp difference between the bottom surface and the rest of the part. A sealed chamber stops drafts from creating a larger difference in temps. Otherwise, The part expands and contracts inconsistently. Even bed temp has been a good thing since the beginning. You want it as even as possible, and the farther from even you get, the greater chance of warp and adhesion loss. Cant solve it, but you can minimize in design.
