No offense in what follows, it’s hard to convey tone and intent online.
The entire point of the encoder plate is to provide a calibrated and known distance measuring capacity for the camera. Each code is a know datum for the camera to reference. It does not make any difference if that plate is slight nudged in any other direction.
The reason for this is simple, it’s using the calibrated distance on the encoder to compare its distance traveled.
The take away point is this… it’s like a ruler for the printer to read.
But the bed has alignment values as well where the head understands its initial position. If that is how the head homes/zeros itself, then plate alignment would matter if in relation to that origin.
Tool head homing position is not the same as a motion system accuracy calibration. It’s accounting for distance traveled and not used for homing/bed position.
I’m running the motion calibration test now with it shifted to the left, and will do the same with it shifted to the right and see what the results are.
Average should be much less than the original, I would assume.
If it’s like my CNC milling machine, it compares how much it was told to move with how much it should have moved based on the encoder plate readings, and then applies a scaling factor to compensate for the error.
My mill also has a separate backlash compensation function.
Presumably the H2D does not have that since it’s not mentioned, so I wouldn’t expect it to be able to correct for backlash.
I think this is what I am not understanding. what does avg/max mean? What is being changed with calibration? How far off is a factory printer going to be and how long will it stay that way? How often is recalibration recommended? What tasks does calibration apply to/benefit from? Is calibration from the factory recommended to achieve the presented accuracy?
Reading the marketing and this thread covers many of the questions but not all of them for me.
I was just being silly, I didn’t really do it. The plate came in the mail today and I had posted on another thread “challenge accepted” when someone said you couldn’t print on it.
