When using points a check is done, always print profiles removed?
When you use your points there is always a check being done on your creations.
All fine.
all have a photo attached.
but i noticed that there are always print profiles removed bcause of no photo’s
The weird thing is that all the prints have real photo’s attached to them.
the only pattern i see is that i uploaded the files and included a screenshot of the product first.
and replace them later on.
Most of the time i forgot to make the photo.
But add them later.
Are the checks being done on the first upload and dont they check the current uploaded version?
It’s important to note that the requirements for photos applies to Print Profiles - not the model page. Even if you have real photos of the print as part of the model page listing, this does not meet the requirement of a real photo being attached to the Print Profile.
As an example, in the following screenshot, you can see that this model has a rendering as the first image in the model listing but a real photo of the printed item as the photo used for the Print Profile:
Ok, that might explain it.
after uploading the photo is might not change it in the print profiles.
Thanks
