When will the developermode available X1C
Is there any visibility on whether and when the developer mode will be available in firmware 01.09.xx.xx for the X1C?
Nevermind, I found it but not the devolper mode I hoped for :frowning:
What were you expecting to find?
Still be able to set the filaments via the SpoolEase project as it worked in version 01.08.05.00
Write NFC-chips with the right info about brand, color, K factor etc. Stick it on the spool and when needed scan the chip, insert the spool and the right info is inserted in the printer/ams.
It works like a charm on non-Bambu spools
See: GitHub - yanshay/SpoolEase
I stand corrected: SpoolEase is working under LAN-only/Developer mode.
