When you put a PLA spool in your new AMS-HT
I was maybe a little too excited to get my new AMS-HT via Halloween sale.
I’d attempted to print some desiccant holders in a new reel PET_G matte. Print failed due to stringing, which suggested moisture. No problem, I’ll just whack it in the AMS-HT and run a drying cycle.
seems I didn’t keep track of the spool I printed in PLA.
D’oh
Pro tip: Just dont print spools out of PLA.
ABS is the better choice. Especially if you plan on drying.
It helps to label everything, either with geometry in the design, or with sticky labels.
You will eventually end up with enough spool cores, either from Bambu or a compatible manufacturer (sunlu version 2 filament comes with perfect fit cores) that you will not longer need to print spools.
Even bambu doesn’t use a high temperature spool on everything. their pla/petg spool is rated to 70C. The high temperature spool they ship with PAHT etc can go higher.
Don’t neglect pure PC filament for spools. True it’s typically more expensive, but your health is worth it (no styrene). And still significantly less expensive than buying empty high-temp BL spools (even as add-ons).
I’m not saying PC is “safe,” just somewhat less toxic apparently. Personally I avoid ASA unless that’s just the best filament for the job due to its properties (which is often, but not for spools).
-Max
