Where are cooling fan speeds specified in Bambu Studio?
Looking thru all the tabs in Bambu Studio and I can’t find where you specify cooling fan speed? Also, can you set Aux Fan speed? I’m having to manually set it each time while the model is printing.
Im not at my computer now but I think you can change the fan speeds inthe filament settings.
Ah, yessiree, they are indeed under the filament settings! (Took a minute to figure out how to get at the settings.) Thanks!
I know this is an old thread, but I can’t seem to find fan settings under the filament’s settings. The menu only opens up to select different filaments.
Welcome to the forum.
Click the “Filament Settings” (1) It will show “Click to edit preset” when you hover over the button.
Select the “Cooling” tab (2)
Thank you Jon, I couldn’t find it either. My question is whether you always use that configuration and what results you have obtained? Additionally, if you always use the same configuration and if it has worked for you. Could you upload a full screenshot to see the other options? Thank you very much.
your a lifesaver we couldn’t have done it without this post
I know you posted this a while ago but thank you so much for the pictures bro! That was a huge help immediately finding out where i need to go to change the fan speed. Especially when you’re completely new to Not only bamboo slicer but any slicer in general sometimes a picture that points at the area I need to click on makes a huge difference lol thanks again bro!
Thanks for the screenshot. A picture is worth a thousand words!
