I just got the Revo Panda as well and was excited to see a 0.15mm nozzle I really wanted to try with tiny prints, but from this thread it seems either very annoying to do, or not even possible, even with Orca? What the heck, why wouldnât bambu just give us the option to set whatever nozzle size we want? To ensure we only buy their nozzles? Thatsâ some ****.
If you send your file to the printer and try to print from the LCD screen, it will give you the error that the nozzle does not match.
You must start the print via Bambu Studio or Orcaslicer. âSendâ your file to the printer, go to the tab âDeviceâ - âMicroSD Cardâ - âModelâ, select your model and âPrintâ. Works for me every time.
hello tout le monde voici la solutionâŠ
Dans lâonglet prĂ©fĂ©rence de Bambu studio (ctrl+p), tout en bas, activer âmode dĂ©veloppeurâ.
Résultat:
dans âparamĂštres de lâimprimanteâ >> âextrudeurâ
-le diamĂštre de la buse nâest plus grisĂ©.
-ajuster les limites de heauteur de couches, personnellement jâai tester en minimum 0,06 et en maximum 0,18 et ça fonctionne plutot bien pour moi.
-pensez a renommer le nom du profil et a enregistrer
Bonne journĂ©e a tout le monde et bon printâŠ
pour la buse Revo en 0,25mm
Hello ! Quand tu dis :
Peux tu dĂ©tailler sâil te plaĂźt ? Je dĂ©bute en impression 3D avec Bambu Studio depuis 6 mois et viens dâacquĂ©rir une RĂ©volution en 0.35 aussi. Merci beaucoup !
Iâm going to explain how I did it, I donât want to say that itâs the most correct or only way to do it. In my case I have an X1 carbon.
I recommend having the âdeveloper modeâ option enabled, but it is not necessary.
Iâm sorry, I have the program in Spanish ![]()
The first thing I did was activate 0.4 and 0.2 in the bambu profiles
Then activate the 0.2 configuration. (1)
Save (2)
Put the name for your nozzle 0.25 (3)
Configure your bed size
Copy these settings if you are going to use 0.25 nozzle
If you have activated the âdeveloper modeâ it will allow you to modify the nozzle diameter (but it doesnât matter), it is very important to leave the nozzle at 0.2. If you donât leave it at 0.2 you will have the following problems:
If you send it to the printerâs SD card and send it directly to print, it will not let you either, you will get this error:
If you have done everything correctly up to this point it should appear like the image on the left.
Save the profile with a different name and set the line width of the image on the right.
The tests I have done have been perfect with this configuration.
Create as many layer height profiles as you want always in the max-min intervals (0.05-0.175mm)
I hope it has been useful to you!!!
Sorry for the slight necro - I skimmed through the thread, and I think it hasnât been posted yet.
Or maybe Iâm misreading the thread - in which case, sorry in advance.
The âcreate new nozzle for existing printerâ dialogue is NOT for Bambu Lab printers.
To add a nozzle to the bambu lab printer, you have to modify the printer settings and add the nozzle. You get there by the gear icon on the top right (of the left hand of the screen).
See also the comment in this thread: Create a Custom Printer or Nozzle | Bambu Lab Wiki
(Currently near the end, from Bambu Lab Moderator)
.2mm works fine. Thatâs all I use for the .25mm Revo nozzle. So far itâs been perfect.
