White haze on bottom of my prints and hot bed plate
Does anyone know why i get a white haze on the botttom of my prints and on my plate? It can’t be washed off with degerent or alcohol. It’s like its stains it and all my prints have a white haze on the bottom.
You need to provide more info.
What plate?
what filament?
what temp?
using gluestick?
cool plate, with pla white that came with the printer, heating to 180, and no gluestick. It was the white PLA that started it all.
You could try dish soap and a good scrub or just replace the cool plate decal with the spare
I use glue more as a releasing agent but also for longevity of my cool plate
The textured plate is rad but sometimes I like the bottom smooth
Same thing, glue stick on my textured plate, and engineering plate not so much for adhesion but more as a barrier between the print and the bed
I use Elmers washable purple glue because it dries clear and goes purple once it’s wet so its super easy to wash off
But ya, try cleaning with a wash, dry, and swipe some isopropyl across with a lint free rag
Otherwise its replacement decal time
Actually it was the first print i ever did that created this problem. I switched cool plates with a new one and printed with black PLA and i noticed it was slightly white again. It doesn’t scrub off. So i will take your suggestion and start apply glue to create a barrier. Thanks -
I get that on prints with ABS filament and get rid of it by quickly hitting that side with a heat gun set to slightly hotter than the filament print temp.
That’s a great point
I use the heat gun where supports leave a scar, and sometimes to help remove stubborn supports
Gotta be careful though lol
I use the wife’s nail buffer stick to clean up any haze. Shines it up too, if needed. :slight_smile:
Im Having same issue. Im pretty sure its from plate glue build up. It seems to only do with bambu filament, due to the insane adhesion to the plate.
Im using the texture plate.
Same issue here on the textured plate I have never used glue or any plate additives as release agents, so this isn’t from a buildup. This is with Bambu Lab PETG-CF. Hitting it with a heat gun appears address the issue, but I’d rather not have to post-process all my prints. Could this residue be part of the coating on the sheets being “pulled up” with the print?
I don’t think its anything coming off the build plate-
I get that with ASA/ABS if I try to remove before cooling. I sum it up as more of a tear/deflecting the surface material due to high adhesion to the plate when removing.
I don’t know what others do, but on the Cool Plate with glue stick, I clean with dish soap and warm water, dry, and reapply glue stick before any important prints, and when needed for unimportant or short prints which is generally every few prints. I have the faint ridges from the glue stick and where other prints have been pulled otherwise.
If the white PLA filament is really shiny compared to other Basic PLA colors, it might be a problem with the filament. Others (and me) have noticed that they swapped filaments on us and at least the black and white have both semi-satin versions (good) and quite shiny (bad). The shiny stuff likes to break during feed/retraction, isn’t quite the same color, and prints poorly. Haven’t heard yet that it creates a haze but why not with everything else?
yeah i have that too. Almost like tiny strands of hair. I think its from the filament its self and not the build plate.
sorry to be a grave digger but mostly it comes from not letting the print cool down, which bends the pla. Depending on PLA and color it differs.
Seriously, how has this not been said yet
Stress marks. Let the plate cool down before removing the print. Next.
Great advice. And I myself always let it completely cool but I get them too. So I don’t think that’s the solution.
Just wanted to chime in and agree with @user_248167191, we have an H2D at work and I will often start a longer print before heading out for the day, then come back the next morning with the bed (obviously) completely cooled yet my print still has the haze. @sprior’s tip of using a heat gun did wonders for my prints though, so shout out to him! I did get a tiny bit of warping on one of my prints when I first tried it so I pulled the print back from the front of the heat gun and dialed back the heat a bit, which prevented warping on subsequent prints as I was cleaning them.
Glad it worked. Instead of using a regular heat gun I use a hot air soldering station (because I already had it but they’re not that expensive) which allows me to set the exact temperature of the air. So I set it at 245C (the same printing temp as the ABS I print most often) and I think that gives me a bit more control over warping and overkill.
They are stress marks caused by over adhesion to your PEI plate. If you let the part cool before popping them it might work. If not you can use Magigoo to prevent them, or a heat gun to remove them.
