I went to do some maintenance today, and I noticed this weird white powder inside the case.
Has anyone ever seen anything like this?
Being on top of the chain leads me to believe it is something coming in the top of the printer. Do you use the printer with the top open or removed?
It’s on at all times. This is actually the first time I’ve ever taken it off.
it’s your PTFE tube rubbing off.
Exactly. It’s ur tube rubbing against the top glass
True, but it’s not only the top glass. I have a riser installed and I get this also. I have found that it also happens when the printer goes to the back right side and the tube hits the edge of the glass rest.
The tube is also rubbing on the cable chain
Is that normal, or am I doing something wrong? Because I haven’t seen anyone else with this issue. So, it makes me think that I’m doing something wrong.
