Who has the Sunlu S4 Dryer? Load/Unloading an issue?
Hey Makers!
Protospyre’s seeking some additional feedback on our latest model that helps with filament dryer loading/unloading specifically the ‘Sunlu S4 Filadryer’
I know it helps out in a shop environment with 4 of these it becomes some what an issue on a shelf and how the lid opens and having the PTFE tube inserted…
Our [MagLink] design incorporates [4] magnets inside that are inserted during the printing which act as a linkage system between PTFE tubing, which makes for a simple method of load/unloading plus not bending your tubes ever. I just wanted to see how many are using dryers and what else is a concern/issue for you!
I’ll be uploading the next component of the [MagLink] system which is a plug n’ play design that will insert into any 4mm I.D Pneumatic Fitting and directly connect MagLink’s to each other which allows the users to pop in a spool - feed through the the fitting ez - feed into [MagLink - Quad] - feed into toolhead! (or AMS!)
Just excited to share this solution with others as I know it’s been a hassle for me it’s had to be someone else’s problem too! So this isn’t an advertisement but simple short description and background to my model!
Let me know!
Do you have a link to your solution?
MagLink - S4 FilaDryer Mod by ProtoSpyre3D
Here’s the direct link, I haven’t received much feedback but this model is due for an update since I’ve been using it. The biggest concern is removal of the “MagFitt” which seats inside the PC4 fittings which connects to the “MagLink” connectors.
Not a huge issue if you don’t plan on removing often otherwise I need to revise the model to make removing easier for users instead of using a flat pry tool to release the fitt.
Let us know if you have any troubles or feedback via MakerWorld!
Happy Printing!
