Why can not add new print bed profiles?
Just like filaments, i want to be able select a “named” print plate profile for non BL plates. After placing that plate and trying to match it with the one in pull down menu every time is not feasible and also prone to mistakes.
As an example; While creating a profile, you set bed temperatures per plate type. Bigu Frostbite has to be set as BL Cool Plate but they are different. with dozens of profiles it is impossible remember which ones you set it thinking of frostbite and which ones left at default. We have to check the filament profile everytime to be sure.
I have read a few post about disabling the “add plate” function but i did not feel like that function was related to what i want to achieve?
Here below what chat gpt thinks about those to plates.
Here’s a direct comparison of the Bambu Lab Cool Plate and BIGU Frostbite Build Plate based on their temperature recommendations for common filament types:
Filament Type Bambu Lab Cool Plate BIGU Frostbite
PLA 35–45°C Room temperature or 35–50°C
PLA-CF 35–45°C Room temperature or 35–50°C
PETG 50–70°C (can stick too aggressively) 50–70°C
ABS/ASA Not recommended (requires higher temps) 80–110°C
TPU 35–50°C Room temperature or 50–60°C
Nylon/PA Not recommended (requires high temps) 80–110°C
PVA 35–45°C Room temperature or 35–50°C
Composite (Wood/Metal/Rock-Filled PLA) 35–45°C Room temperature or 35–50°C
Key Observations:
  1. Bambu Lab Cool Plate:
  • Optimized for low-temperature filaments like PLA, PLA-CF, and PVA.
  • Can handle PETG with adjustments, but care is needed to avoid over-adhesion.
  • Unsuitable for high-temperature filaments like ABS, ASA, and Nylon.
  1. BIGU Frostbite:
  • More versatile, supporting a broader range of filaments, including high-temperature materials like ABS, ASA, and Nylon.
  • Offers strong adhesion at room temperature for some materials, reducing the need for bed heating.
Final Recommendation:
  • If you print predominantly PLA, PETG, or similar low-temperature filaments, the Bambu Lab Cool Plate is sufficient.
  • If you frequently print a variety of materials, including high-temperature filaments like ABS or Nylon, the BIGU Frostbite is more versatile and durable.
It’s because of the way plate information is stored.
It would be nice if they added a couple user defined plates, but it’s not something you can do in a generalized way like filaments, so at best you’ll get some number of extra slots.
It’s not particularly difficult an addition if you know how to build studio, maybe a couple hours work?
Create a User filament profile with the modified plate temperatures set and plate name included in profile name, “Bambu PLA Frostbite” ?
If it will not be possible that will be the route to take. But why doubling the amount of custom profiles, while it can be set in the same profile and everything would be automated. We are now spoilt with the variety of plate choices and each behave differently. There is not clear instructions for plates like POE, PET, PEY from manufactures all they say is " looks cool". No one has any clue how to print with them. We have to make many test prints to find our sweet spots. If we make changes on the same profile things will get messy in no time. Thus for every plate we have; we have to recreate a new filament profile from scratch.
One of the reason i bought a Bambu Labs is because i fed up with spending my limited time on tweaking printers, reentering the same values a thousandth times etc rather than working on a design.
