Is there a way to print faster than 350mm/s? Because I’ve done everything - max flowrates to not allowing to slow down prints for cooling etc. please could someone help me? It always stops at 350…
go to orcaslicer, i’m guessing it harcoded in bambu studio, like the removed calibration menu
how many volumetric speed?
50 mm/s³ in that example.
35 mm/s³ slices at 464 mm/s, 30 mm/s³ slices at 398 mm/s.
The print model is big enough (fills 90% of the bed). I’m going to try Orcaslicer.
I’ve tried OrcaSlicer, but the H2D is not supported yet…
The dumb thing is I was able to run the Max_Volumetric_Flow test from the X1C for it using the H2D profile and it sped up to 476mm/s which is pretty close to 50mm/3 flow rate. Perhaps there is an object modifier setting or something that I need to have?
