Why the F is my Bambu app in a weird language?
Why the holy Fronk is my Bambu app forcing me to change to an incomprehensable language, with two choices
A/ Change to hieroglyphs
B/ Close down the app and come back to this same none-choice without mercy!
Does everybody else want to change to a language we dont know nor speak?
Apologies for questioning this genius move mates…
#1 dont let Murphys Law mess with you
If you ask could it get any worse good ol Murphy will keep being a d**k and make things progressively worse
Now, lets fix your app lol
Open the app and click on the bottom right (the little person icon)
4th selection down from the top is language
2nd option down is language selection
3rd down from the top is english
Hopefully its english you are looking for
And hopefully this helps you kick Murphy square in the n*ts
Not today Murphy not today…
Btw
Sorry to read about your pup, that’s a tough one
And what is it your car is or isn’t doing ?
I’m not the best mechanic in the world but I consider myself the best mechanic in my field lol
Thanks mate, I had precisely found the setting, but I appreciate helping out a mate in need! Much appreciated!
Yeah I shortened the whining part, timing chain broke and likely cleared out the insides of the engine block…
Ill PM you if I get stuck mate, thanks!
Also apologies for whining like a windy beach… :flushed:
No need to apologize bro
Your pug is up in dog heaven with it’s long tongue hanging out in the sky
Timing chain, oil pump, vvt, that sound like cam shaft failure causing a chain of events
Often engines with variable valve timing will start with valve bearing issues that grind a flat spot on the cam lobes
Good thing you’ve got good friends that can help a brother out
If possible eliminate the vvt, obviously your car is an automatic but the valves for a manual transmission don’t have that goofy pin setup in the rollers and drop right in
Unfortunately if you go with those lifters you need to have the ecm flashed, but I never leave any of my vehicles stock because everything in the automotive world is designed to fail so I do my best to work around that stuff even if it means spending money at the moment that I don’t want to it saves me problems down the road
I’m also super easy on my vehicles as you can see in this video lol
Absolutely reach out if you have any questions, you’ve got all my contact info now :metal:
https://www.instagram.com/p/B-De9N8B_VF/?igshid=MzRlODBiNWFlZA==
Well… almost bro… it is a manual 6 shift gear + Racer (Reverse) so it is well manual.
I can barely find the engine in a car so I’m pretty lost without help :confused:
Interesting
Usually manual transmissions have skip shift instead of variable valve timing
