Wierd ticking noise on z axis
I started getting a weird ticking noise when the bed moves down during a print. This happen to anyone else? In the 20+ prints I’ve done so far, it’s never made this noise.
I just heard this for the first time myself on a print currently running (a hueforge print with LOTS of z hopping) I noticed i hear it on mine every time the bed z-hops, thought I’m not sure if its coming from the bed/z axis or from the extruder which it retracting at the same time, after about 20 minutes it went away which makes me wonder if its a spot on my z-axis I need to look at when its done. I’m printing at 0.04 layer height so all that z hoping with very little height progress might have worn away the grease in a spot on mine, If I get a chance to find a root cause, I’ll circle back (I’m not usually very active on forums in general)
Same issue here has started on X1C, a clicking as the z bed moved up or down. It’s periodic clicking and occurs regardless of height however. Seems to come from the front left z-axis where the bed is attached to the rods.
Anyone know how to investigate further?
I have a similar problem too… for a few days I hear these noises while the plate goes up, it seems like something is rubbing somewhere (maybe on the front left cylinder) at regular intervals. I have done all the maintenance of cleaning and greasing the axes, plus I checked the belt and gears under the printer… unfortunately the problem is still there. Solutions?
Po nějakém čase stejný problém. Nějaké řešení?
Any solution on this. Same problem here
Have you found a solution?
Mine is doing this when z probing the bed, front right assembly not sure if its the thread or bearing rod…
Will see if it continues after this print finishes and I can stick my head in there…
