Will not feed filament
I have removed the extruder and check it for clog’s , have pushed a wire thru and still will not feed the filament give me a error (there might be a clogged extruder. and help would be great. i check the sensor and it look good.
https://wiki.bambulab.com/en/x1/troubleshooting/extruder-clog
Use the hex key method several times.
For more debugging, we’d need more info. The fault can be triggered by other failure combinations as well.
