So if I cancel a print, things stop, the nozzle oozes some. Sometimes something else occurs, and the ooze happens.
May we please have a ‘Wipe Nozzle’ button? All it does is goto the waste bucket position and wipes the nozzle once.
Thanks very much for your continued support, you’re doing a fine job!!
That would be nice if it had a nozzle wipe button!
Doesn’t it automatically purge and wipe at the start of a print?
yes, but if you had a wipe button, you could do it manually. like if the extruder isn’t working properly and you are manually extruding.
It does, but I’m talking about situations when I’m manually doing something, or the above scenario when I have a little bit of ooze because of a runny filament or such. I then have to visit the printer or bug whoever is home. And Bambu Studio doesn’t have any sort of console to manually put in Wipe instructions.
You can just press pause and it automatically wipes.
That’s only if you’re in the middle of a print though.
Please add this, this would be great, especially when you control your printer remotely.
I’m in the middle of a print, and there’s an ABS booger that’s stuck on the printer nozzle. It wasn’t there when I pressed ‘print,’ but it’s there now. I know that it’s going to dislodge and stick to the print somewhere. That’s why I want a button to trigger a nozzle cleaning.
