There are differences between raw files (STEP) and print files. Is that known?
hello, the raw ones are just for visual reference, cant be printed. if you want, use 3mf and right click, then click export as one stl
Hi, thank you for your response. I agree with you. The STEP model is necessary when you want to design the top shell, for example, with a CAD system. The problem is that if you use the raw file for designing, the printed version doesn’t fit because of the missing radius. For me, it’s not a big deal, I corrected it myself, but the data should match each other and need to be corrected.
