Those aren’t identical, the match must be:
- Supplier
- Type
- Sub type
- Colour
An eSun PLA+ red and an eSun PLA+ blue are not identical because of the colour.
This is the feature people want to have and have asked for here many times before.
The properties of those two filaments only differing by colour wouldn’t change the slicer parameters.
Currently, there is no option for this. It was eloquently described just a couple of days ago if I remember correctly here in the forum as a request.
With the eSun example, you could tell the printer they are both red and it would grab the blue when red runs out.
You can’t do this with BL filaments because they and not you tell the printer what their properties are.
I didn’t say different colours, I said different filaments. An eSun and a Elegoo may well have different temperature and speed differences.
As I pointed out, colour isn’t an issue as you could fake it with non-BL brands.
The current process is automatic, it isn’t a question of remotely or locally. If you have auto refill enabled, it occurs, it doesn’t matter where you initiate it.
Assuming you are using the Bambu Studio (BS) slicer remotely from your printer’s location, as long as you have auto refill enabled, you choose the starting spool when beginning the print. The printer will then choose the next available matching filament available on the AMS when one runs out. This can occur more than once during printing. You could use up to 16kg of filament with 4xAMS on the P & X series printers or 4kg of filament on the A series.
The same is true if you print using Bambu Handy.
As you are using BL filaments, you cannot use the hack I mentioned by faking the material information. This means you do get the auto refill, but, you don’t get the ability to grab any matching filament if the colour is different.
I imagine this feature will come in an updated BS as the code to achieve it is simple enough, the only complication (albeit limited) is creating the UI changes.
