Wisps and holes
Hi. I’ve had been having issues lately printing cylindrical objects.
  1. There is a noticeable seam which can be ignored on single items, but when I print multiple items, the seam becomes rough.
  2. The inside of the project is full of wisps. At first I thought the filament was too humid, but even using a new filament straight out of an airtight package, the problem occurs.
  3. Occasionally I’ll end up with small “holes” or pit marks on the eternal wall.
Has anyone experienced this and knows of a solution?
Thanks
Wet filament can cause the issues you have listed. It is not safe to assume that filament fresh out of the packaging is dry. Dry the filament per the suggested temperatures from the manufacturer. Since you did not mention the brand or type of filament, it would be wise to calibrate the filament for pressure advance and flow ratio.
Do you have seams set to ‘random’? This also can cause the pit marks you mentioned.
Thank you - that’s useful info. I’ll check both.
What filament is it? Vendor, type, color?
Fresh filament is frequently moist. Those bags slow moisture ingress but are not able to stop it. After weeks or even months at sea…
Thank you - well noted and acted upon!
Good luck! If you continue to have issues after drying, don’t hesitate to come back. Pictures can be quite helpful with diagnosing issues too.
