HI So got my first clog after only having the machine a few days. I swapped the PLA to Hatchbox PLA wood and didn’t even get past the loading. ( after tiral and error it was stuck in the nozzle and i had to do an allen wrench cold pull to get it out- nothing else worked. ) I have the stock .4 nozzle. My other printers had no problem with the wood filament with a standard .4 nozzle. Has anyone had any luck with printing wood filament on this printer? I have the X1c with no AMS. Thanks
Matt
I’ve been using eSun wood with no dramas. Even swapping between other PLA including Glow in the dark and PVA support material.
All setting are standard PLA settings.
Thanks. I’ll see if I can find eSun wood from a supplier here in Europe. Was there a specific temp you used? it was odd it didn’t load it just got stuck in the hot end.
Well I retired the Hatchbox wood and it loaded fine this time and printing ok. Though it looks like the temp needs to be dropped a lot. I oozes a lot at 220, and I just did a temp tower and 195-200 looks more like the desired temp.
Sorry for the delay… but yes, 200deg was great
