There is a significant difference between the default settings and the post-calibration settings.
After calibration, I get values such as
Flow Rate: 0.99 / PA: 0.04 / MVS: 21
Especially the cooling settings seem to need a lot of tweaking too.
How did your calibration results turn out?
If you could share your settings, it would really help others out as well.
That’s called tolerances - which is exactly why you calibrate it in the first place. It all depends on the printer, its age, the filament, humidity, ambient temperature, and the location. Even if you have two 100% identical printers running 100% identical filament, put one in the desert and the other in a rainforest, and you’ll already get different performance.
The default profile only ever represents an average baseline - it doesn’t account for what works best for your individual setup.
