Wrong Hotend Error PETG CF
Hello,
I want to print PETG CF but I keep getting an error saying that a hardened nozzle must be used. This is also built in. However, I still cannot start the print job. How do I tell the slicer that the correct hotend is installed?
greetings
fabi
I only know the X1 but I am pretty sure it is the same with the a1 mini: You need to set it on the printer itself. Use the touchdisplay, navigate to settings and adjust the type.
On your printer. Settings > Maintenance > Nozzle > Hardened. In the latest Studio, the Device Page, top right Print Parts has this setting too now.
You should also be quizzed when trying to send the file to the printer. The slicer now notices and asks you to change in the device tab, status, printer parts button above the printer controls if you haven’t.
