Wrongful ND Takedown on Print Profile (Orientation change only)
I had my print profile for a model removed because of a supposed rights violation on an ND license. All I did was modify the orientation of the model for printing, which doesn’t change any of the model features, scale, etc.
I even appealed this and they doubled down and stated that adjusting the orientation of the model was a violation. They stated “adjusting the orientation of the model is considered as making modifications to the geometry of the model itself.”
This is ridiculous as that’s not making a change to the geometry of the model!
Emails from support below
Hi there,
Thank you for contacting us.
This profile has been taken down due to a violation of model license.
The relevant team had previously reminded you about this matter, but because you did not handle it in time, the printing profile was eventually taken down.
We would like to kindly inform you that when a model is licensed under the Standard Digital Licence or NoDerivatives, profiles uploaded by other users are only allowed to adjust the print parameters of the file. It is not permitted to make any modifications to the geometry of the model itself, e.g. scaling, clipping, mixing, adding negative parts,etc.
For more details, please refer to our Print Profile Upload Guidelines: MakerWorld Print Profile Upload Guidelines | Bambu Lab Wiki
Thank you for your understanding and commitment to our community standards.
Hi there,
Thank you for your reply.
We would like to kindly remind you that adjusting the orientation of the model is considered as making modifications to the geometry of the model itself.
After a manual review by the responsible team, this decision has been confirmed and will remain in effect.
We apologize for any confusion this may have caused.
Thank you for your understanding and support again.
After the ticket being resolved, you’re welcome to complete the satisfaction survey on this ticket regarding our service. Your comments and feedback will help us further improve in the future.Your positive feedback means a great deal to us, and we truly appreciate your support.
Best regards,
MakerWorld
@MakerWorld @Tanklet
More context is needed here, both from your side and from Bambu. The important thing with print profiles is that, at the end of the day, they are better than what already exists. The email is probably just another automated standard response, which is causing confusion.
What was the reason for changing the orientation? What improvements were made to your print profile?
You decided against letting the designer change the orientation. This can lead to significant problems, including misprints. There must be a good reason for this. Generally speaking, only the creator should adjust the orientation, not the person who adjusts the print profile.
For example, I have 3D models whose stability would be completely destroyed if the orientation were changed. What may seem trivial can often have important implications.
Ultimately, both the designer and Bambu are right in their decision because it is the designer’s responsibility to adjust the orientation. If you are unhappy with this, you can either do it yourself or write to them. A discussion here in the forum would not change anything. Incorrect orientation simply leads to too many misprints.
The same issue arises when print profiles with different quantities are published: This can significantly impair print quality because the print head jumps from object to object.
Is that the case here? I can’t say, but keep in mind that I have less information than you do about what this is all about.
Actually - It’s worse than I originally thought. I was the first to offer a .3mf file for this print. I downloaded the STL’s and set up the orientation of them across multiple plates. I colored the model only - and made NO other changes. The only other print profiles are from another user - and one is 50% resize. What exactly are Makerworld staff comparing my model to when they decided that I violated the ND license? This really should be reviewed by staff…
Model:
That is strange, of course, and gives the case a completely new twist. The original creator did not provide a print profile. This means that there is no specified print orientation, nor color or whatever - the claim is invalid.
Just a guess: Someone who doesn’t want to share their points or for other personal reasons has probably reported your profile.
The remaining two print profiles from other users have also been resized and rotated. The only option I see is to ping MakerWorld to make sure that a real human being actually looks into the case.
@MakerWorld - Maybe you should take a look at the case?
If it has a standard digital license and the uploader reports it, it will be taken down 100% of the time; even if you are making no physical changes to the model other than print orientation. I went through this with Bambu already as well and got zero clarity around how I was violating a license by uploading a model that was simply oriented differently to make it more efficient to print.
That’s a really good result! Getting all 63 gift cards extended to 10 years is definitely worth the effort. Hopefully the website updates eventually, but having confirmation from support is reassuring.
I’m assuming you mean ND = no derivatives.
Rotating a model is changing it. It will be sliced differently with different start/stop locations for extrusions even if just rotated in the X/Y plane. Lay it on its side and it’s an even bigger change.
Another way to look at no derivatives is that you don’t create other versions of an ND licensed model. Any change, even just a rotation, is still a change. The only way to escape the ND license is to make no changes but then it’s a straight copy and also not allowed.
I don’t understand why so many think they have the right to modify other peoples’ work - when the people who created the models specifically license their models to prevent that.
Just move on. It’s not an argument you can win.
