X & Y axis issue in studio
Can you please amend the x & y axis colour coded information in studio scale tool it is the wrong way around & keeps throwing me out when I’m attempting to size a part
L
Hi,
There is no problem whith the axis position/color correlation.
X axis goes from the viewer right to left.
Y axis goes from the viewer front to back.
What is confusing is the coloured letters on the numbers do not match the coloured axis lines on the print never had this issue in cura
The colored lines are not the axis but lines delimiting the with of the part in the corresponding axis, that’s why they have the same color as the cubes that point at the extremes of the “real” axis.
I have the same problem, The item I’m printing is 107mm high ( from bottom to top) and 80.91 mm wide ( left to right) and 1.66 thick from bed up.
Yet the scale numbers have x which is the width across the bed as 107 when it should be 80.91 which is green as show in the screen shot. If i scale it to in crease the green the red numbers increase.
why is this backwards.
