Which lubricant do you recommend for the X/Y axes? Strangely, on the Bambu website they recommend a normal WD40 but at least it was the dry PTFE one
In the Wiki, the product recommended is the WD-40 Multi-Use Product which is also a lubricant.
Please note that WD-40 has multiple types of products, and the WD-40 Multi-Use Product is the lubricant is the product which has been tested extensively and the reason why we recommend it for a long lifetime of the printer.
Avoid using other WD-40 products, as some of them are not lubricants, but can be lubricant cleaners, which can actually damage the printer over time.
Besides this product, you can also use the Bambu Lab Oil included with the printer.
Can I use bicycle chain lubricants like Finish Line DRY LUBE TEFLON for X/Y axis?
