X1C AMS Filament Settings
I made a short video about my issues with the X1C and AMS Filament settings
hopefully this can be fixed one day in a firmware update
I donr think this will be fixed in a update. This is because normally it gets the material and color settings using the RFID tags in the rolls from Bambulab. This process only works when the new roll is fed into the AMS, and the new filament can only be feed into the printer if the other filament is fully retracted first. And if it retracts it, it cannot continue printing.
You do know that it only continues to another roll if it’s the same material and color?
yes I know that I can switch to another roll of the same settings, if its setup to do that from start.
any I dont use RFID spools usually.
