trying to print directly from Bambu Studio after updating to this firmware gives 100% failures parsing gcode
edit: to be clear this is with bambu studio ver 2.0.2.57 - i’m rolling back to non-beta firmware on the printer as that was working fine. RIP using my AMS2’s drying functions yet.
moi il a fonctionner avec quelque bug , ne peu pas choisir la langues au redemarrage donc obliger de redemarrer l’imprimante , mais jai reussi a imprimer , et ams 2 pro et pris en charge aussi oui
I updated two of my X1C’s to this and they’re both giving me the same error every time I try to start a print. Even when I try to start one from the SD card. I’m currently downgrading them to the previous version.
Same problem. Internal original g-codes too.
Next problems in this firmware what I found:
Filament sensor not work if using external filament. AMS works OK for me (tested Auto Refill with 4 filaments - all OK)
Not possible (or buggy) regulating fan speeds while printing.
I realy love this new GUI. And from fw 1.8.50.14 is saved K-faktor into filament presets in AMS - not needed to setup it every time after power on.
For the Beta-Versions like 01.08.50.14 Beta, you have to enter the Beta-Firmware-Program. Then you can see this version in the mobile app at the older Firmware list.
You probably don’t see this version in the old versions because you are not on a newer one.
I don´t know if you can choose this version without installing the buggy one 01.08.50.18 Beta first.
I’m OP. I was on the buggy version. When I rolled back it didn’t offer me. The .14 version as an option. Just the 18 and the non beta I had been on previously.
