You’ll be able to go back to 1.7.1, you wouldn’t really want anything less 'cos then you’ll have the all noise as well. You’ll be fine, unless you in the 1% that always has a problem with everything. I must be part of the 99% 'cos I’ve only ever had an issue with one update that I rolled back, it was fixed in few days.
There are people who have upgraded to the newest firmware 01.07.02.00 and do not have to option to rollback firmware so I believe this is still disabled do, to this Rooted: The Good the Bad and Freedom of Choice (bambulab.com) I had had issue’s since I updated to 01.07.01.00 if possible I would recommend staying below 01.07.00.00 plus you will still benefit from the Nosie Cancellation. But that’s just my opinion others have no issue when updating the firmware its a roll of the dice.
In about a week there’s going to be a way to roll back the firmware. Bambu can’t stop it.
Thanks for the replies they’re pretty much what I was expecting. I will always be wary of FW “updates” where the ability to roll back is not possible. I am still trying to sort my Creality Sonic Pad after it was rendered useless with and “update” When I take delivery of my X1 Carbon I will check the installed FW and if it is not too old, run with it until I get a feel for the communities opinions on FW versions. With different manufactures of the same chips on the main board there will always be room for errors to creep in.
you can rollback with the phone app
