X1C chamber fan speed
How can I change the chamber fan speed?
If I use textured PEI plate and PLA, the chamber fan always use 100%, it is too noisy.
In the filament settings advanced tab start g-code
M106 P3 S150 - where Sxxx - xxx is from 0 to 255 , 255 is 100% 0 - is 0%
Depending on the Material and bed temperature this may vary , but for PLA usually around 150 is good .(lowering it too low for PLA may be not a good idea, unless you keep the door open) The original code is based on active filtration and bed temperature if statements, you can modify there instead
In Orca, it is in the cooling tab of the filament settings. On/Off, percentage during print and percentage after print.
My Start Gcode:
{if activate_air_filtration[current_extruder] && support_air_filtration}
*M106 P3 S{during_print_exhaust_fan_speed_num[current_extruder]} *
{endif}
