X1C Displays 180°C When Set to Ambient Temp
Hello all,
Recently and seemingly out of the blue my X1C has become a paperweight. The hot end states it is roughly 180°C even when at room temperature. I have replaced the hot end assembly 3 times with authentic components and the front daughter board on the printhead, I’ve attached some pictures that show how when set to 250°C the hot end ranges from 180°C to 210°C. Also, when set to 0°C the display shows between 175°C and 185°C while the hot end itself is at ambient temperatures (around 20°C). I have been unable to use the printer due to this issue as to even start a print you need to drop below 140°C at some points which is simply not possible right now. I am using the most current firmware and have attempted multiple factory resets with no change. The machine does not give any error codes at any point of this happening.
I’d appreciate any help you can provide here as I am lost as to how to proceed. Thank you!
try downgrading to the previous firmware version that worked well for you
It was on an older firmware when it stopped working so I upgraded in an attempt to fix it which gave absolutely no improvement.
Hi … challenging issue indeed.
To confirm if I understood what you did for troubleshooting:
Do you mean that you replaced the complete hotend three times, i.e. tried three new complete hotends?
If that is the case, you can eliminate the thermistor.
Did you receive any HMS error code, either at the start or after following the self-test procedure?
In any case, you can measure the sensor resistance to confirm: HMS_0300-0200-0001-0002: The nozzle temperature is abnormal,the heater may be open circuit. | Bambu Lab Wiki
What is the daughterboard? Do you mean the interface or the TH board? If so, which one did you replace?
Yes, this exactly. I have tried 3 different full assemblies (Part no: FAH001). Also, I am unable to do the self-test as it requires the nozzle to “cool” below a certain temp to continue on from step 1. Since my nozzle is reading at 180 degrees even when it is actually at ambient it won’t let me self-test or move past the nozzle clean phase of new prints.
I don’t know the exact name for it but it’s the board that all the hot end wiring plugs into. The one that was facing the camera in all of my pictures.
Create a ticket with BBL, they’ll tell you which component is the likely culprit.
It is the “Extruder Interface Board”.
I second this.
You did a thorough checkup of the likely culprit parts.
Unless you have spares for the remaining boards and cables, it will be easier if BL assesses the printer logs to identify the problem’s origin.
I want to tell you that there is a simple provisory solution for continuing printing while waiting. However, the ones I recall require access to the printer firmware or changing the electronics circuit.
Do you know of any way to raise the temperature that the nozzle has to drop to after nozzle cleaning stops? I’d be happy with a work around even if it means sacrificing some luxuries like bed leveling and such.
To add on a new detail. After homing the extruder if I try to jog the machine at all it says, “Before any movement, please home all axis to zero or wait for the end of zero return to detect the boundary of the printing space”. It also seems to be bumping into the walls of the machine while homing.
That could be as simple as the plate being on a little crooked. Doesn’t take much, unfortunately.
I don’t have an X1, so I can’t test myself… but what happens to the temp reading on the display when you unplug the thermistor? Does it blank out, or does it continue to think its 170C?
Personally, if it blanks out… I’d order a new thermistor.
With the hotend completely unplugged the screen still reads 180 degrees
Is this the board you replaced?
Yes but I have the older version. Not the v9.
Have you doublechecked the connections around the board are solid?
For example, turn it on and lightly press in various connectors around the board and see if the display corrects momentarily.
Yes I have. I also took the back off the entire printer and pressed all those connections as well. I also thermal imaged everything to look for shorts and I did notice the back of my extruder assembly had 3 hot spots. One where the light is, one opposite it, and one in the middle.
That will be quite a challenge, requiring hacking the printer code.
I am not an electronics expert, nor do I have a solution. I also believe waiting for BL’s feedback is the best solution.
Nevertheless, from a theoretical viewpoint:
  • The temperature values are faulty by excess;
  • The temperature sensor is an NTC thermistor, so a higher temperature means lower resistance.
  • Emulating lower temperatures requires higher resistance;
I wouldn’t try it at a practical level, as there are many things to consider and many others that can go wrong, with a reduced benefit. Also, it will take time to design a proper circuit, access every risk, and fit it into the system, and it would require calibrating the probe.
Small update:
Bambu is sending me 2 replacement boards for the toolhead, and they seem to have no idea what is causing the issue either. If this doesn’t work idk where to go next. Maybe Bambu will try to take the printer to fix on their end. Not sure…
I have the same issue with an X1E stuck at 224 degrees since today. I hope there will be a solution. I will contact BambuLab tomorrow.
I am glad to know that they are assessing your case.
I hope the issue will be solved with a new board :crossed_fingers:.
If not, and considering there isn’t a clear indication of the error cause, I can’t imagine any more straightforward solution than trying to replace other boards or cables.
Please share the outcome.
