X1C Heated bed does not heat
Hi everyone,
Yesterday my X1C with AMS finally arrived and I already have a technical problem.
In the meantime that the Technical Team answers me, and it seems that half of China is once again stuck with a new Covid-19 variant, I wanted to ask if anyone has experienced this defect, i.e. that the heating bed does not work.
I have a fixed value of zero degrees and when I try to heat it always stays at zero.
Can you help me or do I have to ask Bambu to replace a new printer, given that by law I return within 15 days?
The printer arrived yesterday and immediately the heating bed did not work.
Thank you all.
Tony - B2B
Can you please check this issue according to this guide?
If the problem is still there, please create a ticket with enough information. Exporting 3D printer logs to micro SD card | Bambu Lab Wiki
Hi Mr. CHen,
thanks for your reply,
I have already opened a ticket, Ciprian replied and gave me the same link.
As already written in the ticket, today around 14:00 Italian time, I will disassemble the printer as per the Wiki you suggested.
We are experts in 3D printers and I will be able to tell you if it is a broken, disconnected or other cable/electronics board problems.
I’ll update you later.
Thanks,
Tony - B2B
Hi Rochy,
problem solved, but now I paste the ticket here too because the ticket area does not accept more than 1000 characters (please lengthen it).
Here photos also:
Hi Cyprian,
first of all I want to tell you that I have solved the problem but, let me tell you what problems I have found and, in my humble opinion, which mechanical aspects should be reviewed.
I followed the wiki guide to the letter and, although I successfully solved my bed heating problem, I encountered the following problems/breakages:
  1. The plastic support where the waste filament chute is screwed is split, (see photo) in fact when I opened the rear panel and was about to unscrew the two screws at the top that support the chute, I couldn’t find them and, one moment later, I understood why.
Practically the slide was already detached from the support that supports the whole printer (the screws were screwed to the slide), so now I put some rings (obtained from the split edges of the general support. Later I’ll go buy some small washers to fix everything better In practice, the chute remained in its position only because there are two screws that screw into the rear panel.It is clear that while traveling this printer took so many sharp blows until it broke the support.
  1. The first check that the wiki help manual recommends, is to check that the 6-pin cable that is correctly connected to the board, and was correctly connected and, here I would correct the Wiki manual because it could be easier to check first the two-pole connector coming from the heatable bed. In my case that was the problem.
At first it seemed that the cable was very short, but it’s not like that, the cable is of the right size, the problem is that at the exit of the heated bed, just 1.5cm comes out and there is silicone blocking this cable. and it is difficult to connect the connector on the temperature control board, because if you keep the bed up, the connector can never reach the control board.
Instead, pulling the cable from the bed compartment, the silicone came off, and enough cable came out to connect the connector comfortably.
ATTENTION, on the Bambu forum, news is passing that this cable is very short, when in fact it is not.
Finally I ask you, how should I deal with the broken support? Should I leave everything as it is? Can you give me an advice?
I await news.
Thank you.
Tony - B2B
Hello there.
I am currently facing the same problem regarding the print bed.
I also checked the plug-in connections, but everything seemed to be in order here.
What exactly solved the problem for you?
Did you ever find a fix? I am currently having the same issue. Brand new, never used before.
Wondering if you might be able to shed a little more light on your fix. I am having the same issue and can’t get anyone to get back to me. It’s a brand new printer, never printed anything, and I’m not electrically savvy enough to understand everything.
